It is currently Fri Oct 16, 2026 6:28 am
 Post subject: Tandy PCC Parts
PostPosted: Sun Jul 08, 2012 8:23 pm
The second list of parts from the Tandy #5 are now on the web site for North Texas Transport. You may see the original list and the new list at
http://www.northtexastransport.org/Surp ... alvage.pdf
http://www.northtexastransport.org/Surp ... lvage2.pdf
Harry Nicholls
 Post subject: Re: Tandy PCC Parts
PostPosted: Mon Jul 09, 2012 8:22 pm
Any photos of the heaters?
PostPosted: Mon Jul 09, 2012 8:39 pm
If you mean electric heaters from inside the car, there are none. This is a stripped body on the inside that was getting ready for a new paint job when the project was cancelled. We do have a MG set which is not out from under the car. It will be available as soon as we clear the car underside. All other under body parts, controller, compressor, etc., will be taken out later this month.
Right now, we will have to concentrate on cutting up the GE switch box to be able to have access to the under side.
Harry Nicholls
