It is currently Sat Oct 31, 2026 10:25 pm
 Post subject: Duplex Sander Valve
PostPosted: Sun May 27, 2012 2:09 am
Saw this at a flea market today.
I've never seen a sander valve with "Notches" before. Is this a unique design, or is it common and just something I haven't noticed? The seller had no info on it at all. ("I think it might be for the air brakes?" LOL!)
As you rotated the handle, it would seat in each notch, but was also easy to continue to rotate it. I presume the notch you chose determines how much air flow passed through?
 Post subject: Re: Duplex Sander Valve
PostPosted: Sun May 27, 2012 8:03 am
Last edited by Kelly Anderson on Mon Aug 05, 2024 11:00 pm, edited 1 time in total.
PostPosted: Sun May 27, 2012 11:49 am
How many out put pipe connections are there? There were valves made that allowed one to have sand turned onto the #1, #1 and 2, #1, 2 and 3. The idea being to use only as much sand as needed rather than have them ALL going at once.
Perhaps this it's one of those.....
Jason
PostPosted: Sun May 27, 2012 12:04 pm
Jason, I didn't buy it, so I can't check, but from what I recall from looking at it, just two, which would mean one each front and back. It appeared, from a very casual inspection, to increase the air flow as you went.
I was *guessing* these used the air to actually propel the sand like a sandblaster, more air meaning more flow.
It could be the design you mentioned though, and I simply missed seeing the other connections. Unfortunately, I only got the one photo.
PostPosted: Sun May 27, 2012 1:23 pm
Bob, the orfice diameter increases with each notch off of center to allow increased air flow: first notch least flow - last notch full blast. There is also a "warning port" which keeps the engineer aware that the sanders are actuated. The button can be depressed to shut off the warning, which was probably just a hissing of air if dirty or whistle when new.
PostPosted: Sun May 27, 2012 1:29 pm
Thanks, Adam. That's exactly how I guessed it works, but if there's one thing I've learned in this business, it's that things aren't always what they appear to be. ;)
PostPosted: Sun May 27, 2012 5:32 pm
Our sanding valve on the 765 is similar to the one in the photo.
