It is currently Sat Oct 31, 2026 9:48 pm
 Post subject: Need Air Reservoir
PostPosted: Tue May 22, 2012 3:51 pm
I am looking for a 16" x 62-68" main reservoir with center drain cock and air fitting at one end. Does anyone have a source for this?
 Post subject: Re: Need Air Reservoir
PostPosted: Tue May 22, 2012 11:36 pm
If you have a drawing or can make a drawing and specify the maximum working pressure, any ASME code shop can make you one.
PostPosted: Wed May 23, 2012 12:57 am
Several organizations have found Stoystown Tank and Steel to be an economical place to have custom tanks made. http://www.stoystowntank.com You will need to be able to descirbe what you need including the maximum operating pressure. ASME usually require two 2" openings for inspection of the interior. These are usually placed in the center of the heads. You can bush these openings down to the pipe size you need.
If this is for use on railway equipment, you may want to read the FRA requirements for resevoirs before you contact Stoystown at 49 CFR 229.31 and 49.
