It is currently Wed Oct 21, 2026 2:29 pm
 Post subject: 660 Bronze
PostPosted: Sun Sep 08, 2002 8:35 pm
Anyone know of a supply/vendor of 660 bronze. I am looking for Bronze bushing stock with an OD of 15"
 Post subject: Re: 660 Bronze
PostPosted: Sun Sep 08, 2002 11:17 pm
Poured cast, extrusion cast or spin cast?
PostPosted: Sun Sep 08, 2002 11:24 pm
If you're making valve rings Bob, make sure you don't go with the poured cast.
PostPosted: Mon Sep 09, 2002 9:54 am
Robbie, Centrifigal cast bronze, any ideas for 15"?
 Post subject: Techni-Cast
PostPosted: Mon Sep 09, 2002 4:30 pm
This is a good place for centrifugal castings.
Techni-Cast
 Post subject: Re: Techni-Cast
PostPosted: Mon Sep 09, 2002 10:32 pm
> castings.
Matt's suggestion sounds like a good one in your part of the country Bob.
Doyle had some cast for the '49's valve rings (12"), but I don't remember whether it came from a local outfit. He may be able to tell you, if he can still remember after all the Bondo exposure.
 Post subject: Re: Techni-Cast & H-S Gun Metal
PostPosted: Tue Sep 10, 2002 4:38 am
The Challenger has been running since 2000 with Techni-Cast C90500 centrifugal cast, fine grain structure for the bronze and CL30 (A-48-30) for the iron, also centrifugal cast. This was the closest match found to the HUNT-SPILLER Gun Metal Bronze and Gun Iron cast iron ring material.
Anybody want to guess where the phrases "Gun Metal" and "Gun Iron" came from?
PS Techni-Cast makes the special mix formulas for a very famous Texas valve and piston ring manufacturer.
Techni-Cast
 Post subject: Re: Metal Tek
PostPosted: Tue Sep 10, 2002 5:43 pm
I always use Metal Tek ( formerly Southern Centrifugal) in Tennesse.
Good Luck.
jasonsobczynski@yahoo.com
