It is currently Sat Oct 31, 2026 11:06 pm
 Post subject: Fuel tender questions
PostPosted: Thu Apr 12, 2012 8:58 pm
The IRM is making up a separate informational sign for the 24,000 gallon fuel tender attached to our UP gas turbine locomotive and I need to fill in a couple of blanks.
UtahRails has been a big help with early history. They I.D.ed the original car # as UP 907853
“Insulated, classified as 24-C-GTE, and was rebuilt from 20-C tenders from retired FEF-1 class 800-series 4-8-4 Northerns”
Two things we still need for our sign.
The original builder, ALCO? UP?
Weight? I did some subtraction of 200,000 lbs water from Loco and tender information and came up with an empty weight of 365,150 lbs.
Any help appreciated.
 Post subject: Re: Fuel tender questions
PostPosted: Thu Apr 12, 2012 9:29 pm
Well wouldn't you need to acknowledge both Alco as original builder and UP for the conversion (unless it was contracted out)?
There was some discussion awhile back (which I cannot find now) upon the completion of the most recent conversion of an oil tender into a water-only canteen. (Removing the heaters, and stripping the insulation and sheet metal jacket, etc.) I know there was a rumor that they were built by cutting two FEF-1 tenders in half and welding together two rear sections. That rumor was debunked, wasn't it?
PostPosted: Fri Apr 13, 2012 2:00 am
Wasatch Railroad Contractors did the conversion of at least one of the former turbine fuel tenders to a water car for UP. Pretty sure there was only one tender involved originally- not two halves welded together- at least if the pictures of the stripped down tender showing its original black paint and silver lettering are any indication.
http://wrrc.us/about/highlighted-projec ... ar-no-814/
David Wilkinson
Salt Lake City, UT
