It is currently Sun Nov 01, 2026 1:54 am
 Post subject: News on the original NS heritage fleet
PostPosted: Sat Mar 31, 2012 7:12 pm
Maybe I should put this in Flimsies, but its just as relevant here
http://www.timesfreepress.com/news/2012 ... rack/?news
Matt Bumgarner
 Post subject: Re: News on the original NS heritage fleet
PostPosted: Sun Apr 01, 2012 8:25 am
This is a very good and positive article! One amendment I would make is this: This is a more extensive overhaul than the locomotive ever had even with the southern. The entirety of the inner firebox sheets are being replaced, the backhead (this was never done prior), major....MAJOR running gear work, modernization with a stoker, etc, etc......
Cheers, Jason
PostPosted: Sun Apr 01, 2012 1:09 pm
Not quite so, we have found records from 1943, where the 4501 went through an extensive post-wreck rebuild. It was in the shop, IIRC, 4-6 months. This was a high traffic period for the Southern and unless something was just trashed it was overhauled as quickly as needed to get it back on the road. That fact alone, plus some of the write up on that tells of an extensive rebuild.
PostPosted: Sun Apr 01, 2012 4:22 pm
SR6900,
Since it is "post-wreck", would that not be repair of damage versus a class overhaul as it is getting now?
Cheers, Jason
PostPosted: Sun Apr 01, 2012 5:02 pm
Is there a hope or beliefe that they will be able to get it straightend out/squared up and quartered properly this time around?
Brian Rogers
Knoxville TN
That which is seen is temporary, that which is unseen is eternal, therefore, focus on the unseen things.
