It is currently Sun Oct 25, 2026 8:03 pm
Post new topic Reply to topic  [ 62 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Help searching for MLW FPA/B-2/4s
PostPosted: Mon Jan 02, 2012 8:23 pm
Yes, I was. Thank you. That info filled a gap in what I had. Did these come from VIA directly or from a dealer?
I know that the "B" units are more difficult to trace, I am also in need to get histories on these.
Thanks for your help.
John
PostPosted: Mon Jan 02, 2012 9:25 pm
The B units are "Dark Territory" mostly.
PostPosted: Tue Jan 03, 2012 3:10 pm
Carroll Cameron wrote:
A couple of corrections for the FPA-4 list
6768 MPA-18b
6773 MPA-18b
6776 MPA-18b
6793 MPA-18b
This is the FPB-4 tech notes
6860 CN 6860 1958 FPB-2u MPB-18a 12V-251B 1800 62:21 92mph 2 Vapor-OK 4625 Retired 1989 Ex-CN 6860. Retired in 1989
6871 CN6871 1959 FPB-4 MPB-18b 12V-251B 1800 62:21 92mph 2 Vapor-OK 4625 Retired 1989 Ex-CN 6871. Retired by 1989.
The FPBs are rather short on history right now. The FPAs have more then what I posted however I have that info spread out in to different files and I haven't started to put it together yet.
Carroll
Carroll, all of these are on Grand Canyon Railway, along with 6762. email me directly hadder@xanterra.com if you need updated info on these units.
Eric
PostPosted: Wed Jan 04, 2012 10:26 pm
arjay3 wrote:
There is a pair on the NY&LE at Gowanda, NY and an A-B set in Illinois at Monticello.
RWJ
RWJ. Thank you for your post. I apologize for not responding to it. I totally missed it.
Carroll
PostPosted: Thu Jan 05, 2012 1:30 pm
The A-B set at Monticello have also been restored to the 1950's CN Green and Gold paint scheme as shown in the link below.
Ryan
http://www.flickr.com/photos/wales23/5006307239/
PostPosted: Thu Jan 05, 2012 8:20 pm
Thanks Ryan
They are a beautiful sight.
Carroll
PostPosted: Mon Jan 09, 2012 1:23 pm
John
I'm assuming you're talking about the Napa Valley units. If so here is a list. Carroll
6760 - #70 Converted to run on compressed natural gas / Diesel mixture
6775 - #71 Back up power
6787 - #72 Back up Power
6790 - #73 EMD powered
I'm not sure about #70, but #67 is spark-ignition EMD and can be seen here.
CD
PostPosted: Mon Jan 09, 2012 10:55 pm
John
CD
Interesting, I haven't heard of any locos running on natural gas yet, I'll have to see what info is out there. It's definitely grabbed my interest. Is the natural gas and diesel running together or do they switch between one or the other?
PostPosted: Mon Jan 09, 2012 11:03 pm
They start out on diesel and switch over to gas. When they go to shut down they reverse the action.
ALCO had diesels that could run on a variety of fuels going back to the 539 engine.
PostPosted: Tue Jan 10, 2012 12:02 am
It's straight natural gas. ECI converted the EMD 2-stroke to spark ignition, there's no diesel fuel aboard what so ever.
ECI also converts to dual-fuel, using slightly modified Diesels and injecting natural gas to burn cleaner and be less expensive on fuel. Have a look at their web site - it's crude but informative: http://www.energyconversions.com/
CD
PostPosted: Tue Jan 10, 2012 9:22 pm
So much for the old trick of sending the new worker to the stock room for "a set of EMD spark plugs". When I first saw the "EMD spark ignition", I thought, "Is somebody trying to see if the readers are paying attention?"
Bob Davis
Southern California
PostPosted: Tue Jan 10, 2012 9:26 pm
John and others.
This is an update to my 2 posts of Dec 27/11 on the GC units.
I left 6762 off the tech notes and that is at the bottom of my post.
Here is the current status of the Grand Canyon FPA/Bs
6762 and 6768 are parts engines
6793 and 6860 are active.
6773, 6776, and 6871 are currently stored serviceable.
6793, 6760, 6773, 6776, & 6771 have been converted to freight gearing and
their steam generators have been removed.
6762 Tech notes
6762 1958 MLW FPA-4 MPA-18a 12V-251B 1800hp 62:21 92
1 Vapor-OK 4625 Ex-CN 6762. Retired by 1989.
Sorry for the mix-up
Carroll
PostPosted: Tue Jan 10, 2012 9:36 pm
This is a great help Carroll. Thank you.
PostPosted: Tue Jan 10, 2012 9:42 pm
CD
#73 is indeed on CNG as the previous posts have mentioned. I for some reason transposed the CNG onto #70 even though all the info I had on NV stated #73 was totally converted to CNG in 2008.
It is 1 of about 3 Locomotives in the world that run on CNG (napa valley website 2008)
Carroll
PostPosted: Wed Jan 11, 2012 3:04 pm
John and others.
6762 Tech notes
Carroll
I would like to confirm a couple of things....
6793 is listed as both active and having freight gearing. Is this correct?
Are all of these X-VIA and CN?
Are all of these on the current roster?
It appears that they(Grand Canyon) have quite a few units.
