It is currently Sun Nov 01, 2026 11:50 pm
 Post subject: Air compressor repair stand
PostPosted: Sun Oct 02, 2011 11:39 pm
We are preparing to build a repair stand for 8 1/2" cross compound air compressors here at the Monticello Railway Museum shop. Does anyone have a good design for one of these that you would share with us?
Some of the features we are looking for are:
1. A base that can be lifted with either a fork truck or overhead crane.
2. A mounting arrangement that allows plenty of room around the compressor to work during assembly.
3. A design that will hold a fully assembled compressor and allow it to be laid down on its back or stood upright while mounted on the stand.
4. Built from standard, readily available steel shapes.
Any ideas will be appreciated. Thanks for the help.
Russ Fischer
 Post subject: Re: Air compressor repair stand
PostPosted: Mon Oct 03, 2011 1:26 am
I doubt anything is available commercially, but you may want to do what the New York Central did and cobble up your own from angles and plates, and mount the whole thing on a base that would be both stable and have the holes in it, like a pallet, for your forklift. Just hope the forklift has enough lift for the stand with a compressor on it!
http://books.google.com/books?id=EY4jAA ... nd&f=false
http://books.google.com/books?id=PJQjAA ... nd&f=false
Hope this helps out.
PostPosted: Mon Oct 03, 2011 11:37 am
For single stage air compressors, we've had great results with bent bars of steel bolted to a metal bench. It allows you to work around the air compressor, and being located next to a crane makes installation easy. Plus, steam up a locomotive and connect a flexible steam line to allow for easy bench testing. The small metal bench can easily moved out of the way with a forklift.
PostPosted: Mon Oct 03, 2011 4:58 pm
I built a stand like this a few years ago that is now owned by the Travel Town Museum Foundation. I built it out of heavy wall box tubing and heavy angle. I mounted a 20 or so gallon tank on it for the compressor to pump into for an orifice test. I have photos somewhere, I'll try to dig them up and post them.
PostPosted: Tue Oct 04, 2011 1:40 am
You might try getting a hold of the CMO at the NMSL&RHS. The club built a stand that held both of our cross compound compressors while they were rebuilt. The only thing it did not do was lay over on its side. (your #4)
Here is a shot from last years open House.
http://nmslrhs.org/images/photos/Open_h ... _1506.html
This is the club web site.
http://www.nmslrhs.org/index.php
And just for fun here is a shot from last Sat. at this years Open House, with the compressors remounted.
http://www.nmslrhs.org/images/photos/11 ... 10019.html
Regards,
Kevin
Russ Fischer
