It is currently Thu Oct 29, 2026 4:19 am
 Post subject: Okadee
PostPosted: Fri May 06, 2011 12:55 pm
Does anyone know what happened to, or who last owned the Okadee company and/or the parts that this company made?
I need to find the drawing sets for the cylinder cocks (& relief valves) and the smoke box door hinges.
 Post subject: Re: Okadee
PostPosted: Fri May 06, 2011 2:26 pm
Greetings:
OKADEE (valve division) was acquired by MAXON Corp. at Muncie, IN. Last June, I spoke to Michelle: 765-284-3304 looking for parts for blowdown valves (the Chinese standard blowdown valve is a copy of an OKADEE). She said that it was obsolete, no parts or drawings available. Parts had been available as recently as 1993...
J.David
PostPosted: Fri May 06, 2011 2:35 pm
Where do you suppose the Drawings went?
Maybe they just do not want to "pull" them for you or anyone else.
If they are still around and not valued by their present owner I'll volunteer to have them cataloged and have them placed into a railroad library.
I wonder who got the "Hinge" division?
PostPosted: Fri May 06, 2011 3:13 pm
Those should be pretty simple drawings. If you have one or can find a loaner you could try taking it to your local community college or trade school and asking if they can make a CAD drawing of it for you.
Tom Gears
Wilmington, DE
PostPosted: Fri May 06, 2011 5:37 pm
I'm amazed that parts were still around in '93 for the cylinder cocks and relief valves. I never thought to check them, thinking they were long gone. They are relatively simple apparatus and I just rebuilt them with what I had for the 1522. Had no need to mess with the hinges.
PostPosted: Fri May 06, 2011 9:26 pm
Blowdown parts only were available. The ONLY route (IMHO) is to replace with modern everlasting.....which is virtually if not identical to vintage everlasting. With parts available well into the future.
Locomotive cyclopedias are a great resource for the rest.
Jason
PostPosted: Sat May 07, 2011 11:34 am
Last edited by Kelly Anderson on Sun Aug 04, 2024 9:49 pm, edited 1 time in total.
PostPosted: Mon May 09, 2011 1:36 pm
This is kind of a shot in the dark, but Superscale does produce Okadee parts for the 1/8" scale live steam world. Perhaps they have some drawings? Here's their website: http://www.superscale.biz/Superscale2/Index.html
Gerald
PostPosted: Tue May 10, 2011 1:24 pm
Probably the reason they will not release the drawings is the same reason that Fairmont railcar (HARSCo Track) will not release theirs, Liability.
If you make one of their parts using their drawings and something unintentional happens then they are legally liable even if you machine it wrong, where as if you reverse engineer one of their products the liability is entirely on you.
Rich C.
