It is currently Tue Oct 06, 2026 11:13 pm
 Post subject: New track at Strasburg?
PostPosted: Mon May 02, 2011 10:18 pm
Some photos were posted recently of what appear to be new track construction going on at the Strasburg Railroad. Photos can be viewed here: http://Forums.Railfan.net/forums.cgi?bo ... start=1100
Is there anyone at liberty to disclose a bit of information? ;)
-MCH
Visit the NKP 765's website: http://www.fortwaynerailroad.org
 Post subject: Re: New track at Strasburg?
PostPosted: Tue May 03, 2011 6:59 am
I'm putting my money down on a loop track. Strasburg does see occasional freight car unloading/storage, so it would make sense that you need an extra spot for those cars.
Dylan M. Lambert
PostPosted: Tue May 03, 2011 9:49 am
BIDS track for Mr. Weaver's Wonderful Patent Plastic Pellet Transfer Machine?
Erik Ledbetter
www.steamsafari.com
PostPosted: Tue May 03, 2011 5:12 pm
Hah-hah! Close, Erik, and "Mr. Daylight." It's a new sixteen-spot team track to handle growing traffic, half of which will be paved to rail height in order to preserve SRC parking during our busy times.
PostPosted: Tue May 03, 2011 11:36 pm
Out of curiousity, if Strasburg is seeing an influx in freight traffic, are employees getting covered under RRR?
PostPosted: Wed May 04, 2011 7:02 am
AFAIK they always have been. Or at least had that option.
PostPosted: Wed May 04, 2011 10:05 am
Wasn't there talk of installing a turntable at the facility? I was just there on the 22nd standing right where they are working.
Later!
Mr. Ed
PostPosted: Wed May 04, 2011 10:58 am
@ MFolland, always have.
@ Mr Ed, not for a while.
PostPosted: Thu May 05, 2011 12:16 am
What's the cost to lay track these days? Figure a passing spur on a main line, big enough to accomodate an engine, tender, and 3-4 coaches?
PostPosted: Thu May 05, 2011 7:03 am
I think that Strasburg trains run in the area of 7-8 coaches. Might want to double that length, and accomidate for a tender. So about 10 coaches in length.
Dylan M. Lambert
PostPosted: Thu May 05, 2011 10:13 am
Good ballpark is $165/foot for new sidings. Your mileage may vary ...
PostPosted: Thu May 05, 2011 11:01 am
So, if i'm doing my math right, that's $1,650 for every ten feet. Man, the depot is going to need to raise some money for a display track...
Dylan M. Lambert
PostPosted: Thu May 05, 2011 11:33 am
Keep in mind, that's on a "prepared subgrade", i.e. you have a piece of ground that's to grade and able to support the track. If you need any earthwork, that's in addition to the $165 per foot.
On the other hand, if it's simply a display track, you may be able use second hand (relay) materials, and cut that $165 cost significatly in some cases.
PostPosted: Thu May 05, 2011 12:41 pm
Thanks S!
Later!
Mr. Ed
PostPosted: Thu May 05, 2011 1:54 pm
I just had 21,000+ feet of County owned track rebuilt for $115 per foot. New sidings were $130.00 per foot including excavation. This was in northern NJ. Used No.1 relay 136 lb rail.
New #10 turnouts ran $55,000.00 each, 10 total on the job.
Surfacing and aligning track cost another $5.00 per foot and ballast was $20.00 per ton, installed. Excavation was $30.00 per cubic yard.
cv the civil E in NJ
