It is currently Tue Oct 27, 2026 4:58 pm
 Post subject: Beartown (MA) trolley line history
PostPosted: Mon May 02, 2011 3:54 pm
http://www.berkshireeagle.com/ci_179626 ... st_emailed
 Post subject: Re: Beartown (MA) trolley line history
PostPosted: Tue May 03, 2011 10:44 am
It sounds like that article is describing Bates expanded steel poles, often used for trolley lines. Apparently there are quite a few of this line's metal poles still in place in the woods of MA. I have not seen any Bates poles in preservation, but a few still in service along the CTA and other places.
PostPosted: Tue May 03, 2011 11:03 am
Bates light pole formerly located along the railroad, now installed in the parking lot at IRM:
http://www.irm.org/gallery/Light-Tower
Actually this pole can still be seen in outdated Bing birds-eye views at 40th Street halfway between Halsted and Emerald in Chicago.
Frank Hicks
Hicks Car Works
PostPosted: Tue May 03, 2011 12:12 pm
Yeah, but that's not the classic Bates line pole, which was tapered, and only had a single layer of "lacing".
There used to be two of these on Main St. in downtown Lemont, IL left over from the Chicago & Joliet. One held a rotating red beacon for the fire station, while the other still had a wood strain insulator dangling unused for forty or fifty years. I imagine they are gone now.
Years ago I looked at some along the CTA Skokie line, but as was typical of these things, the base plate and nuts that held them to the footing had been covered with a concrete cap, and were very deteriorated. Nothing that couldn't be repaired with some welding, but the repair would need to be designed by a structural guy if they were to be used to support something.
