It is currently Mon Nov 02, 2026 11:42 am
 Post subject: Wash out plug sealant
PostPosted: Wed Mar 30, 2011 10:50 am
Just wondering what product you all are using to seal boiler wash out plugs & how successful they are.
Looking for a product that does not harden to concrete.
DBH
 Post subject: Re: Wash out plug sealant
PostPosted: Wed Mar 30, 2011 12:04 pm
Why not just use regular automotive, Permatex, anti-seize compound? It comes in a large jar with a brush.
PostPosted: Wed Mar 30, 2011 12:14 pm
First of all. I assume you are talking about tapered threads. Rectorseal has a high temperature sealant with PTFE. Teflon tape works as well.
For the square thread plugs you need a good copper gasket and some anti seize on the threads.
Tom Gears
Wilmington, DE
PostPosted: Wed Mar 30, 2011 12:18 pm
Graphite powder mixed with valve oil to form a paste.
PostPosted: Wed Mar 30, 2011 12:31 pm
Slic-tite works good. It hardens, but not as hard as concrete. Gasoila doesn't work.
PostPosted: Wed Mar 30, 2011 1:01 pm
The best sealant is excellent condition threads on both the plug and the sheet.
A traditional sealant is fine flake graphite and steam oil mixed to a consistency of a paste. I think the primary function is that this reduces the friction of the threads allowing the plug and sheet to be run together harder or maybe it actually fills the holes. A problem with this is that the graphite will fill the root of the threads after a while so careful cleaning of the threads is necessary each time the plug is reinstalled.
A good quality non-hardening steam rated pipe dope works well because, well, it is for sealing threads. It is essential that the threads be clean before assembly of the joint. And of course be sure the threads are in good condition.
PostPosted: Wed Mar 30, 2011 1:18 pm
Thanks for all the Info. We may try the graphite & valve oil. Just have to weigh our options.
DBH
PostPosted: Wed Mar 30, 2011 3:55 pm
We switched from a pipe sealant and Teflon tape to steam oil and graphite a few years ago and have never looked back.
Taylor
PostPosted: Wed Mar 30, 2011 4:27 pm
If there's anybody on this list not making a good cleaning and inspection of the threads an integral part of the washout procedure, now is the time to put it in. It didn't occur to me that anybody might not be doing that. Also please do remember to breathe..........
PostPosted: Wed Mar 30, 2011 4:33 pm
Yep Dave, always clean the threads on the plug & the boiler. We are using brass plugs because we had leaking problems with steel ones. We machined the plugs in our machine shop.
Dave Huffman
PostPosted: Wed Mar 30, 2011 8:48 pm
We just put plugs in our engines a couple weeks back. Someone mentioned using brass plugs and I believe they are superior to using steel since the threads are softer. At both steam railroads I've worked for, we made a point to keep the plugs wrapped in a towel and to replace them in the same holes they came out of.
As everyone has mentioned, clean the threads on the plug and then wrap it a couple of times with thread tape. We also use some Key-Tite to help make the seal. Just smear a little over the tape once they've been wrapped. You might also take a tap to clean the threads on the boiler if you want to get extra grit out.
I'm interested in the graphite and valve oil, I might try that on one of the easy to reach plugs, but we have enough Key-Tite to last 10 years.
This is the end of my post.
PostPosted: Wed Mar 30, 2011 9:19 pm
John, we numbered all our plugs & have a container with numbered holes for each plug. There is a there is a line drawing with all the plugs listed. This has worked well for us.
Dave Huffman
PostPosted: Wed Mar 30, 2011 10:55 pm
Plugs machined from STEAM BRONZE ( not brass) show better service than steel plugs because bronze expands more than the steel boiler sheets they are installed into, Not because they have softer threads to be deforemed when installed too tight.
PostPosted: Thu Mar 31, 2011 9:15 am
You are correct Gary, I will have to check, ours may be bronze but they sure look like brass.
DBH
