It is currently Thu Nov 19, 2026 7:26 am
 Post subject: Just a weekold update...
PostPosted: Thu Feb 24, 2011 12:55 pm
Should have posted this Sunday of last week, but have just totally forgot. I think the picture says quite a bit.
Edit: The sandome has been off for a few weeks now, it was the cab that was removed last week.
File comment: Two major obstacles have been removed.
183936_194762710541750_122199547798067_678136_8060142_n.jpg [ 101.91 KiB | Viewed 3469 times ]
-Aaron Farmer
Manager, Mechanical
Steam Railroading Institute
 Post subject: Re: Just a weekold update...
PostPosted: Thu Feb 24, 2011 3:07 pm
Sand dome question: There are 5 ports on the sand dome. Is the 5th port an air intake or is it a sandline going to the trailing truck booster? Thank you for tolerating this non preservation question.
Tom P
PostPosted: Thu Feb 24, 2011 3:22 pm
Tom Parkins wrote:
There are 5 ports on the sand dome. Is the 5th port an air intake or is it a sandline going to the trailing truck booster?Tom P
1225 has one sander in front of each driver, plus a fifth one behind the main.
Walt Lankenau
PostPosted: Fri Feb 25, 2011 12:56 am
Tom P
Attached is a very basic diagram....basic is the key word...
-Aaron Farmer
Manager, Mechanical
PostPosted: Fri Feb 25, 2011 12:24 pm
Is that rear sander used primarily for back up moves? Can it be independently operated?
PostPosted: Fri Feb 25, 2011 12:30 pm
The fifth sander is for back-up moves. I assume it can be used independently.
-Aaron Farmer
Manager, Mechanical
