It is currently Thu Nov 19, 2026 10:08 pm
 Post subject: Re: Amtrak SDP40F cab and font questions
PostPosted: Fri Jan 28, 2011 1:48 am
Chris- just curious, what's the bulk of the cost? Restoring the nose sheetmetal, or the actual paint job? Is just painting #644 into Amtrak colors without restoring the original nose contours out of the question?
David Wilkinson
Salt Lake City, UT
PostPosted: Fri Jan 28, 2011 2:52 am
The bulk of the costs would go to hiring someone to fabricate the steel and fix up the nose. Some steel work also needs to be done at the tear-drop corner of the windshields. Then there's scaling the paint off of the carbody, which would take up lots of time! I estimate $4-5,000 for the paint job, including primer and paint supplies with room for error in case a flock of birds decide to fly by and leave their mark, which has happened to me a couple times. Or if someone runs into a fresh paint job with the man-lift (which another volunteer did three separate times last summer...)
Lastly, the big question: where to do the work since this weekend is 231 and 644's last at Brooklyn.
PostPosted: Sun Jan 30, 2011 7:04 pm
Is it still an active effort to get the 644 operational for Amtrak? I don't know if there's anything I'd like to see more than a SDP40F in Amtrak colors...but if there was a possibility to have Amtrak use the locomotive???
PostPosted: Mon Jan 31, 2011 4:05 am
The 644 is operational, but there are no plans to return this unit to Amtrak colors before the 40th Anniversary event. The main reason is: Money. Funds are needed to restore the nose and repaint the locomotive, and at this time we don't have the cash nor a place to do the work.
PostPosted: Fri Feb 04, 2011 5:02 pm
Thought I'd share an update on 644's cab. With help from others on the prep-work, this is what we were able to do. More work is needed near the tear-drop portion of the windshield, and the ceiling.
I sprayed seafoam green using Centari Enamel, which turned out very nice despite the fact that more crap from the problem areas continued to fly around while I was spraying.
PostPosted: Fri Feb 04, 2011 6:28 pm
Looks great Chris! How about adding two pairs of fuzzy dice hanging from the visors?
David Wilkinson
Salt Lake City, UT
