It is currently Tue Oct 27, 2026 11:00 pm
 Post subject: CTL&F Locomotive Glenbrook
PostPosted: Tue Dec 28, 2010 4:34 pm
The good news from NSRM is that we have successfully navigated the grant writing process and are in receipt of sufficient funds to complete the Glenbrook, an 1875 Baldwin narrow gauge 2-6-0. This come at a good time given the general financial situation of museums in general.
As some of you may know the Glenbrook project began in 1983 and has started and stopped several times during the last 27 years. With a dearth of funds for other projects we can work unhindered on this project.
The boiler is on the shop floor. We have un-stitched it about as far as one can and still have it remind you of a boiler. The steam dome is off, the barrel is off at the throat sheet, and the rear tube sheet is out. The wrapper has received a new liner. It is riveted in and the dome is ready to be re-installed. We have new sheets rolled for the barrel and the new rear tube sheet is on the form and partially flanged. The transition course will require flanging also.
Meanwhile we have disassembled the pistons and are preparing to put in new hard- chrome plated rods. We have just received a donation of a universal cylindrical grinder and re-worked the heat treat furnace. This will allow us to machine, harden, and grind new valve linkage pins and knuckle pins. We have welded up, normalized, and machined a new steam dome lid (the original is cast iron and in poor condition). While the boiler is going together the cab, pilot, jacket and sundries will be in process.
The tender was completed several years ago as was the frame and wheels.
While the Glenbrook is only several builders’ numbers off of Markoff’s Eureka, it isn’t the blistering beautiful piece that his is. This was a bare bones work engine. The contrast will be interesting.
We are proceeding with the intention of returning the locomotive to full operating condition. We have allowed four years to complete the project but hope to complete it sooner.
File comment: This is obviously taken from the side and shows the new rivets for the liner below the dome and some of the new rivets in the dome flange. This boiler has the oddity of the wrapper being flanged up into the dome hence the rivets in the barrel of the dome.
The dome was removed to facilitate the installation of the liner and to allow for the replacement of the rivets. The original rivets were iron and the heads badly corroded. The fastenings in the barrel of the dome were patch bolts which are to be replaced with rivets as soon as possible as stipulated by code.
File comment: This is the Glenbrook boiler, shot from what would be the front of the locomotive. As you can see the barrel is off the boiler and the rear tube sheet is out. The dome is partly riveted in. The edge of the new liner is just barely visible inside the wrapper.
 Post subject: Re: CTL&F Locomotive Glenbrook
PostPosted: Tue Dec 28, 2010 5:18 pm
NSRM?
CTL&F?
Any hints here as to "who, what, where"?
Thanks,
 Post subject: Google strikes again
PostPosted: Tue Dec 28, 2010 5:39 pm
Quick search turned up the answer:
http://www.nsrm-friends.org/nsrm51.html
John Isaksen
PostPosted: Tue Dec 28, 2010 6:17 pm
Apologies for the presumption.
Nevada State railroad Museum
2180 South Carson Street
Carson City, Nevada 89701
775-684-6953
Carson Tahoe Lumber and Fluming Company, operating a railroad from 1875 to 1898 from Glenbroook, Nevada on the shores of Lake Tahoe to Spooner Summit, a distance of approximately 10 miles with a gain of a little more than 1200 feet.
Chris De Witt
PostPosted: Tue Dec 28, 2010 7:55 pm
Sounds like a really invasive project! The rivets in the boiler could not have been straight out iron, perhaps wrought iron. The corrosion of rivets, flexi caps and sleeves is an odd thing. On many locomotives I have witnessed HEAVY wasting of the previously mention items while the surrounding plate goes untouched. W
While it is no doubt a matter of the material composition I have never heard a narrative as to just what allows this to occur. Anyone?
Cheers, Jason
PostPosted: Tue Dec 28, 2010 8:29 pm
Chris,
Looks good, I remember you talking about doing this type of repair a few years ago. I suppose you gave me some ideas for my engine. :-) Is the barrel and taper course also going to be of riveted construction or welded? I can't wait to see the Glenbrook completed. All the best from Washington state and a happy new year!
Best,
Stathi
________________________
Efstathios I. Pappas, MS
Cumbres and Toltec Scenic Railroad
spappas@cumbrestoltec.com
209 603 7363
PostPosted: Wed Dec 29, 2010 12:03 am
In response to jasonsobczynski, yes of course wrought iron rivets. Pure iron is found in the laboratory and cast iron is obviously not an option. It is understood in the trade that when the word iron is used in conjunction with rivets the wrought is implied.
CCdW
PostPosted: Wed Dec 29, 2010 9:29 pm
Is this at the Boulder City or Cason City muesum? Isn't the muesum in Carson City supposed to close? Good luck with the restoration
PostPosted: Thu Dec 30, 2010 12:08 am
The work is being done at the Carson City facility.
The closure of many of the state museums is threatened by the budget proposed by the outgoing Governor. The new Governor will have to propose a budget and the newly elected state legislature will have adopt it (or a version of it). The next budget will go into effect at the first of July.
For some current information see this post by Dan Markoff over on the Narrow Gauge Railroad Discussion Forum.
The Nevada State Museum crisis
This is in a parallel thread about the Glenbrook.
Dan Markoff besides being the owner of the E&P EUREKA is also on an advisory Nevada Board of Museums and History.
There seems to be a growing awareness in Nevada about the proposed critical cuts to the state museums and the Nevada Historical Society.
PostPosted: Thu Jan 03, 2013 11:43 pm
While I do not have any news on the topic, here are two photos of "Glenbrook" on the last day of 2012. It has been reported elsewhere that the Nevada State Railroad Museum would like to complete this work by 2014 for their state's sesquicentennial.
File comment: "Glenbrook"
Randolph Ruiz
AAA Architecture
