It is currently Tue Nov 03, 2026 12:24 am
 Post subject: 765 Exhaust Steam near number board
PostPosted: Wed Nov 17, 2010 11:17 pm
What is the source of steam emitted next to the exhaust stack and numberboard in this photo?
A friend from school is curious, and now, so am I.
- Michael J. Muldowney
 Post subject: Re: 765 Exhaust Steam near number board
PostPosted: Wed Nov 17, 2010 11:51 pm
Two different individuals have informed me it's exhaust from the air compressor.
PostPosted: Thu Nov 18, 2010 12:50 am
They must have added that, it used to exhaust thru the smoke stack thru the smokebox, perhaps the recent overhaul caused this.
I wonder as the exhaust could cause a backlash in the smoke box and the fire heating and smoke. Probably a smart move.
PostPosted: Thu Nov 18, 2010 8:10 am
I also appears they used some type of muffler arrangement. I have seen a few locomotives whose compressor exhaust does not go through the smokebox and it is quite loud.
PostPosted: Thu Nov 18, 2010 11:12 am
The device appears on NKP Berks from their in service days.
Rob
Rob
PostPosted: Thu Nov 18, 2010 12:25 pm
Indeed. I remember the external air pump exhausts on 759 back in the day. It was often audible over the track noise when the engine was drifting at speeds under 30 mph. It was much louder and sharper (as I recall it) than the sound of an air pump exhausting into the smokebox.
PostPosted: Thu Nov 18, 2010 12:59 pm
Speaking of 765, I'm curious as to why the numberboards have C&O style numerals in them instead of what I was used to seeing on NKP engines?
PostPosted: Thu Nov 18, 2010 1:05 pm
The numberboards in C&O style reflect the "as-built" condition of the 765. The Chesapeake and Ohio and Nickel Plate had common ownership until 1947.
The NKP style numerals will return next year.
Kelly Lynch
Executive Director
PostPosted: Thu Nov 18, 2010 1:45 pm
Big steam is not my personal favorite, kind of prefer smaller logging/mining or mid size locomotives. But I must admit this is one awesome locomotive, great picture. Sure would get my blood pressure going if I was standing next to it. Thanks, John.
PostPosted: Thu Nov 18, 2010 2:06 pm
The 30" 2-8-0 I worked on had it's exhaust routed internally, was originally an exterior with a muffler. Made it very tough to fire, every time the compressor hit it was like a birthday candle at a party. Not sure if that would effect a locomotive this large but there is a reason to design I've found.
James Maxwell
Missoula, MT
Steam Traction Engineer
PostPosted: Thu Nov 18, 2010 2:22 pm
Kelly -
And the Mars light too?
PostPosted: Thu Nov 18, 2010 11:28 pm
Kelly -
The mars light was tested and restored worked over in its original restoration.
It was a decision to give it the as built appearance.
Just as a subthought I wonder if giving the engine a 767 look and celebration as this is the reason for 765's survival.
PostPosted: Sun Nov 21, 2010 6:01 pm
That is where the air compressors exhaust, and it goes through a muffler so it is not so loud. It makes a more pleasing muffled sound, Striaght air compressor exhaust is loud.
PostPosted: Tue Nov 23, 2010 1:03 am
Here's my walk around video of NKP 765 all steamed up at Alma College during the SRI's fall Alma Special trip:
Nickel Plate Road 765 (Steam Locomotive Tour), 10-23-2010
http://www.youtube.com/watch?v=xO7rBrfG8AY
Enjoy! ^_^
You can see the 2nd steam exhaust working here.
http://www.youtube.com/user/jrahrig" target="_blank
PostPosted: Tue Nov 23, 2010 2:56 am
Is there any specific reason why the air compressor exhaust would be vented in this fashion? From a engineering, operational, or maintenance point of view.
I have found the air compressor exhaust to provide a convenient slight draft on my fire while a locomotive is still. However, if it's exhaust is not vented through the smokebox this air compressor induced draft should not exist.
My initial guess is outside vent eliminates a pipe from the hot, particulated environment of a smokebox.
