It is currently Tue Nov 03, 2026 12:07 am
 Post subject: HT Stoker and A&WP 290
PostPosted: Thu Nov 11, 2010 1:53 pm
Does anyone have a HT Stoker manual, parts lists, or service info? Either scanned or be willing to let me borrow so I can scan them?
I am the project manager for A&WP 290 and need info on the stoker.
And before a rumor starts - at this point we are working on a cosmetic restoration. We will however be doing UT measurements of the boiler. The boiler is almost totally stripped for this process. The ultimate goal is to get the boiler blasted and painted.
I would also welcome any comments on what experiences others have had using any alternative to sand blasting. I do not want to introduce any sand into the running gear. I have heard of baking soda and dry ice. Pros, cons, experiences?
Thanks,
Dale
 Post subject: Re: HT Stoker and A&WP 290
PostPosted: Thu Nov 11, 2010 4:21 pm
Dale,
Check your email.
Mike Tillger
PostPosted: Fri Nov 12, 2010 12:18 am
Dale,
I've got quite a bit of info on my website about dealing with the HT stoker, specically about how to split the stoker screw without destroying it when separating the engine and tender.
http://www.trainweb.org/j.dimech/journal/
http://www.trainweb.org/j.dimech/6167/6213-1.html
Joe
PostPosted: Fri Nov 12, 2010 12:33 am
It is possible to blast the boiler using recycled glass ( sand is illegal in most states for open air blasting due to the silica content) without introducing grit into the machinery. This can be accomplished using 6 or 8mil plastic sheeting, spray adhesive and duct tape. I did the same which you desire on an operational locomotive this year...no problems at all. After blasting it needs to be painted with thurmalux 260 http://www.dampney.com/Products/Product ... oductID=51
PostPosted: Fri Nov 12, 2010 4:04 pm
Hey didja hear about the 290?
PostPosted: Fri Nov 12, 2010 9:12 pm
We also used recycled glass on 6167, it was called Greenblast. We used soda for the running gear.
