It is currently Wed Sep 30, 2026 9:57 am
 Post subject: drawbar pins
PostPosted: Sun Sep 26, 2010 5:46 pm
What material and in what condition is being used to make new drawbar pins?
TIA
BK
 Post subject: Re: drawbar pins
PostPosted: Sun Sep 26, 2010 7:06 pm
Baldwin Specs call out SAE 1020 or 1022 (not casehardened) turned from solid bar, see a copy of the spec at the following link, look under pins - drawbars - engine & tenders
http://s776.photobucket.com/albums/yy43/miketillger/?action=view&current=BLWSP19B-1.jpg
Hope this helps,
Mike Tillger
PostPosted: Sun Sep 26, 2010 7:33 pm
The Santa Fe folio only mentions "medium Carbon Steel Forgings, annealed". Also references a materials folio which I don't have. Then 1022 or even 1045 should be just fine. Thanks Mike.
BobK
