It is currently Thu Aug 27, 2026 6:14 pm
 Post subject: That'll Buff Right Out
PostPosted: Sat Jun 19, 2010 8:14 pm
Whenever you hear of someone restoring, say, an E or F there usually seems to be quite a few little dings in the nose to deal with, pounding out or Bondo-ing. So where do these come from? Not collision damage of course (hard to imagine a collision of any sort resulting damage that minor). Impacts with tree branches, rocks falling off overpasses (or maliciously hurled), icicles? I'm sure that's some of it. What else?
 Post subject: Re: That'll Buff Right Out
PostPosted: Sat Jun 19, 2010 9:02 pm
Most of the lumps on IRM’s E and F units come from the steel swelling into rust at the sills. I can’t tell you how much these things remind me of all the former GM cars I’ve owned.
PostPosted: Sat Jun 19, 2010 11:32 pm
Dents in the lower portion of E and F unit doors (including the nose door), are often the result of trainmen kicking an uncooperative door to open or close it, such "sticking" often caused by rust swelling of the door and/or frame.
Jeff
PostPosted: Sun Jun 20, 2010 12:31 am
The Ex CNR F7 cab at the john street roundhouse certainly seems to have its fair share of dings and dents.
PostPosted: Sun Jun 20, 2010 1:06 pm
A letter to the editor of one of the enthusiast magazines about published photos of New Haven RR's newest passenger electric electric locomotives explained some of the dents in the lower noses. The person who connected the heavy steam hoses would signal the engine crew that it was safe to turn on the steam generator by pounding on the locomotive with the same hammer just used to assist in closing the hose couplings!
PostPosted: Sun Jun 20, 2010 11:30 pm
Jeff’s post got me thinking about lumpy GG1s.
One of the most distorted car bodies at the IRM is the GG1. Looks almost as if it had been rolled. Check out this photo of 4930.
http://www.rrpicturearchives.net/showPi ... ?id=530754
Did GG1s pass through deep snow a lot, or just have thin sheet metal?
PostPosted: Mon Jun 21, 2010 2:27 am
The above pic of the CNR cab unit also looks like it's been stripped of the 'bondo' used to fill and smooth the weld seams on the nose at some point.
David Wilkinson
Salt Lake City, UT
PostPosted: Mon Jun 21, 2010 6:17 am
Eventually as work progressed on the CNR cab, they did fill in a lot of the bumps and bruises.
PostPosted: Mon Jun 21, 2010 10:44 am
Another factor that caused some pounding, I'm sure: Trying to pound loose moist/stuck sand from either the sandboxes or their passageways. As I recall, the sand on these locos is in a reservoir underneath and beside the engineer's and fireman's seats..... the square hatches are underneath the cab windows and beside the cab doors. And having had to try and deal with rust repairs inside a cab and right in this area, I second the rust theories as well.
PostPosted: Mon Jun 21, 2010 12:09 pm
I assume the GG1's skin is load bearing; in which case the wrinkling reminds me of the wrinking you see in the skin of B-52; and is result of years of twisting and pulling while (in the case of the B-52) the cabin areas underwent pressurization and de-pressurization.
-James Hefner
Hebrews 10:20a
PostPosted: Mon Jun 21, 2010 2:08 pm
Ditto. It's the same effect one sees on all weld boxcars, with the sheets bowing or warped between their line of attachment to the framing.
PostPosted: Mon Jun 21, 2010 2:58 pm
Interestingly, on B-52's, the wrinkles go away while inflight.......
I wonder if some of the E/F nose dings are the result of structural flexing? I have seen many GP's that have cracked and dented the sides of the electrical cabinet- mostly due to hard coupling.
PostPosted: Mon Jun 21, 2010 3:14 pm
Hmm...interesting. I wonder if the dings in E/F's go away at speed?
-Runs for cover-
-Aaron Farmer
Manager, Mechanical
Steam Railroading Institute
PostPosted: Mon Jun 21, 2010 11:55 pm
When preparing WP805A for painting, I took many wheelbarrow fulls of sand and rust out of the nose and under-cab area. Rust was so heavy in some spots from the sand that there are sections of the I beams with no center web. You can actually see the sag in the body on one side from the structural loss. Not many folks realize that the F units are built like a truss bridge and rely on the upper framework to keep the "floor" straight. It's just a bridge between the two truck bolsters. Some folks argued about my doing so much "unseen" work, but if you don't, it rots through to the outside.
Filling nose dents is about all one can do, sans large hydraulic-powered dent removal equipment--and torches too. That's some heavy metal there!
David D.
Steamcerely,
David Dewey
