It is currently Mon Oct 19, 2026 3:18 am
 Post subject: Air hammer selection
PostPosted: Mon Apr 22, 2002 7:09 pm
Trying to understand the ideal make/ model air hammer folks use for rivet and staybolt work...I am supposing theres a stroke & whacks per minute that is best for riveting and staybolt work as opposed to a rivet buster or general air hammer work. What works ? What doesn't ? Wheres a good source for these tools and parts ?
Bill
staybolt@bellsouth.net
 Post subject: Re: Air hammer selection *NM*
PostPosted: Mon Apr 22, 2002 7:34 pm
staybolt2@netscape.net
PostPosted: Mon Apr 22, 2002 7:42 pm
dear bill i have found the best size for riveting is a 90 . for driving you can use a 60 or with more work a #3or4 hammer. iron bolts drive easer than steel. i may be able to get you some air tools but need to know more details. that is all bob.
PostPosted: Mon Apr 22, 2002 8:44 pm
I have seen pneumatic hammers on ebay and in fact they have been reasonable. For setting staybolts I like a #2 as that doesn't seem to rattle the life out of the adjacent bolts. A 90 is great for those big mudring rivets. What ever hammer you settle on make sure it has the tool holder so that the rivet snaps don't shoot across the shop.
Robert@trainorders.com
PostPosted: Tue Apr 23, 2002 12:20 am
One source for air hammers and other air tools is Michigan Pneumatic Tool at:
michiganpneumatic.com, 1-800-521-8104.
They also have rebuilt, hard to find air tools, but they are a little expensive.
Ron Larson
Southwest Steam Locomotive
swstmloco@aol.com
 Post subject: Air hammers for sale
PostPosted: Tue Apr 23, 2002 1:43 am
I work at Backshop Enterprises, and we have dozens of reconditioned air hammers in several sizes for sale. Give Bernie Watts, the owner, a call after 10:00am MDT at the shop number: 303-424-6882.
V/R billbondie@ironhorsewater.com
http://www.ironhorsewater.com
PostPosted: Tue Apr 23, 2002 10:36 pm
> rivets.
We use two No 60 hammers for riveting. (up to 7/8 inch rivets) We use one of the hammers and a bucking bar to hammer the staybolts. We ground a 3/4" snap so that it had a slight indentation for doing the staybolts. Same with the bucking bar. To grind the snap I put it in a lathe and used a surface grinder to take out the hole that fits the rivet head.
Not a bad idea but it will take some of the exctement out of the job.
JCG
johncgra@locl.net
