It is currently Wed Nov 04, 2026 3:39 am
 Post subject: Window Repair for Lackawanna MU Trailers
PostPosted: Thu Feb 04, 2010 11:09 pm
In Lackwanna MU trailer cars, the original wooden window sashes were replaced with metal sashes that had the latch mechanism inside the sash. On surviving cars it is often the case that either the thumb lever on the latches is broken so that the window cannot be raised or the spring that operates the latch pin is broken so that the window will not stay in the raised position. Are such sashes repairable? Is there any source for parts?
Any information or advice would be appreciated.
Craig Sansonetti
 Post subject: Re: Window Repair for Lackawanna MU Trailers
PostPosted: Fri Feb 05, 2010 9:40 pm
A tourist RR I used to be associated with had the same problem with the same cars. They resorted to using sticks to prop the windows open, and constantly reminding /warning patrons to no mess with the windows.
Didn't Adlake make those latches? I think they're still in business, maybe you can check with them.
Steve Zarick
PostPosted: Fri Feb 05, 2010 10:46 pm
I have the drawings from Adlake, but they will be difficult to find, as they have been boxed up since 1987. I think they are complete enough to engineer, though.
I got them while I was general car foreman for Steamtown Foundation, and stopped by in Elkhart to visit Adlake. They gave me the drawings, but had no interest at the time in retooling to make those parts.
(I believe they are Model #25 sash, but my memory may fail me).
File comment: Almost, but not quite, the same window, being refurbished for a 1952 Decatur-built caboose
File comment: . . .and the print
PostPosted: Sat Feb 06, 2010 2:27 pm
Well surely someone has some original parts you can pull or send to the foundry. Tis the season.
Would the parts lend themselves to CNC milling or weld fabrication?
