It is currently Wed Nov 04, 2026 10:33 am
 Post subject: Re: Rare First Generation GE 70 Tonner to be Preserved
PostPosted: Tue Dec 15, 2009 8:28 pm
"Did that train just blow through that stop sign?"
Wheeling through downtown Hubbard
Setting the first truck on our display track.
PostPosted: Tue Dec 15, 2009 8:29 pm
And finally, 70 more tons of historic iron now call the Tod Engine Heritage Park home!
PostPosted: Tue Dec 15, 2009 8:46 pm
The engines were included with the locomotive right?
PostPosted: Tue Dec 15, 2009 9:29 pm
Yes. We pulled them out to get the weight down. They will go back in next year after we've had achance to clean and paint the engine compartments.
BTW each genset weighs 5,500 lbs. Carbody 71,000 lbs. and each truck weighs 23,000 lbs. I love cranes with load cells!
PostPosted: Tue Dec 15, 2009 10:24 pm
Also, what condition was this unit in mechanically when retired?
PostPosted: Tue Dec 15, 2009 10:48 pm
It was running when it was parked for the last time in 2008, but as you can plainly see it hasn't had much care over the past several years. The bottom of the cab sides need some patches, the hoods need work and several of the doors straightened and new hinges. Both Cummins engines run, but I don't know how worn out they are. Air compressors are fairly new, but the main reservoirs may have to be condemned due to thinning behind the straps. There are the remains of the sister engine still over at EEC, and I have asked for permission to strip parts from it that we may need for this engine.
PostPosted: Sat Dec 19, 2009 6:18 pm
The moving bill came in the mail today:
80 ton crane $2,140.00
Crane permits $350.00
tractor trailers (3 loads) $2,570
Hauling permits $175.00
Total to move a GE 70 tonner five miles in three truckloads, including loading and unloading: $5,235.00
Good deal?
PostPosted: Sun Dec 20, 2009 10:39 am
Normal for a short haul. Longer hauls require two separate crane companies, hence two bills, and the hauler gets more.
Later!
Mr. Ed
