It is currently Fri Oct 23, 2026 12:11 pm
 Post subject: Reproduction Brass Tags
PostPosted: Sun Dec 06, 2009 9:23 am
Does anyone know of a company that can reproduce brass tags?
This original EMC control stand ID plate is well worn and I would like to replace it.
HI-RES photo,
http://www.prrllc.com/images/LV-112-CS-Plate.jpg
Thanks,
Scott Kwiatkowski
Pennsy Railcar Restoration LLC
 Post subject: Re: Reproduction Brass Tags
PostPosted: Sun Dec 06, 2009 11:15 am
http://www.oldengine.org/members/evans/plates/index.htm
Yes he is in South Africa, but I've not found anyone else who would redraw the tag and make a new one for you for thirty bucks!
PostPosted: Sun Dec 06, 2009 12:02 pm
Last edited by Kelly Anderson on Sun Aug 04, 2024 8:30 pm, edited 1 time in total.
PostPosted: Mon Dec 07, 2009 9:31 pm
Guys,
Thanks for the responses.
The guy in South Africa looks like he does nice work but I would rather keep my money in the good ol US of A.
Scott
PostPosted: Sat Jun 12, 2010 10:09 am
I wonder if these trophy and engraving shops would be able to make new dials for steam gauges, such as this one:
PostPosted: Sun Jun 13, 2010 3:32 pm
Scott - this is metal etching and by doing an internet search you will find several companies that can do this in a variety of material. You will need to provide the artwork done in a vector drawing program such as Adobe Illustrator.
Several years ago I had a company in eastern PA etch replica EMD builders plate out of SS just like the real ones. See photo.
R. Jahn
File comment: Etched Stainless plate hand painted after etching
PostPosted: Tue Jun 15, 2010 3:30 am
I was able to make a reproduction badge for the scarifer cylinder on my steam roller by the following procedure. I obtained a photograph and a rubbing of an existing although damaged badge. A friend skilled in Photoshop was able to create new artwork from the photograph and rubbing of the old badge. Lots of company's who do chemical milling were able to do a shallow etch in a brass plate but Lancaster Metal Science in Lancaster, PA was able to do a deep etch in brass, similar to the badges that were soldered to old fashioned copper fire extinguishers.
PostPosted: Wed Jun 16, 2010 6:38 pm
Scott - please consider these guys they do good work, but moreso castings. Need to ask Dennis the owner about ID plates.
http://www.creativecastingco.com/index.htm
Mike
Island Rail LLC
PostPosted: Wed Jun 16, 2010 7:28 pm
Guys,
Thanks for all your great suggestions.
I should have posted the results sooner. I used Kelly’s suggestion and went to the local trophy shop, Crown Trophy, Flemington. After a couple of adjustments the plate came out pretty darn close and they saved the file so additional copies are as simple as sending an e-mail.
I am also looking for an original EMC builders plate to make reproductions. So some of the other business are worth hanging on to once I find one.
Thanks again,
Scott
