It is currently Wed Nov 04, 2026 10:58 am
 Post subject: Baked enamel signage.
PostPosted: Thu Nov 12, 2009 6:03 pm
Greetings,
I am looking for a source of baked enamel sign makers, or the modern day equivalent. Preferably a company that specializes in low volume runs. I can't stomach vinyl.
Thanks.
Chris Allan
WPRM Steam
J. Chris Allan
WP 165 Restoration Blog:
http://wprrsteam.blogspot.com
 Post subject: Re: Baked enamel signage.
PostPosted: Thu Nov 12, 2009 7:14 pm
Winsor Fireform Porcelain Enemel
Tumwater, WA
360-786-8299
http://www.winsorfireform.com
Cherokee Porcelain Enamel Corp.
Knoxville, TN
865-637-7833
http://www.americanporcelain.com
PostPosted: Thu Nov 12, 2009 8:59 pm
Thank you for not stomaching vinyl.
PostPosted: Thu Nov 12, 2009 9:06 pm
Vinyl may have its place, but that place is not anywhere near a steam locomotive.
Purist, CT
PostPosted: Thu Nov 12, 2009 11:28 pm
Don't forget that some railroads did apply decalcomanias to there equipment including steam locomotives (CNR for example). Vinyl is far superior to decals.
PostPosted: Thu Nov 12, 2009 11:47 pm
Yes, I will concede that, joe. :-) Temporary vinyl herald appliques have been used to good effect on Strasburg's CNR power and on OHCR's GTW 4-8-4.
But vinyl or not, the pattern of the letters should be a perfect match to the original-- no modern "Helvetica" or "something close" will do.
Pet Peeve, CT
PostPosted: Fri Nov 13, 2009 12:20 am
An example of Vinyl's longevity can be seen on CNR 6213. It had Vinyl decals applied in 1985 and they are still on the engine, although they are not as shiny as they used to be and the colour is a bit faded. They were made by the same company that used to make decals for CNR (Canada Decalcomania).
