It is currently Tue Nov 03, 2026 10:29 pm
 Post subject: Update from upper Maine
PostPosted: Thu Apr 09, 2009 11:10 pm
I consider Phillips, Maine, one of those "special places" for railroad preservation. Such a nice, rural environment... and a the Sandy River and Rangeley Lakes was a unique railroad with a good preservation history, particularly for such an early abandonment in the preservation era.
Quite of few updates have been posted to the projects page on the website. I thought I would help spread the word about this good place with a recap of some news.
http://www.srrl-rr.org/
Work on the boiler for Ex- Monson 3, a Forney style locomotive, is progressing, though there was a small setback with a cracked dry pipe. It is announced the steamer will be restored to near as-built condition, at least cosmetically. Therefore the engine will lose its Edaville-era Pyle electric markers and gain an older style headlamp. It is planned to return to service in 2009.
http://www.srrl-rr.org/Projects/Monson_3/Monson_3.htm
The reconstruction of Sandy River coach 5, a carbody retrieved by the group many years ago, is nearing completion.
http://www.srrl-rr.org/Projects/Coach_5/Coach_5.htm
Coach 20 is on a long term lease from MNGRM and an inspection of its dry rot has begun.
http://www.srrl-rr.org/Projects/Coach_20/Coach_20.htm
Another carbody restoration - Boxcar 155 - is basically completed, including the replica tin roof.
http://www.srrl-rr.org/Projects/Box_155/Box_155.htm
An Edaville coach made from Bridgeton and Harrison boxcar 54, leased from MNGRM was returned to service.
http://www.srrl-rr.org/Projects/BH_54/BH_54.htm
Edaville excursion car 104, another leased car, was also returned to service.
http://www.srrl-rr.org/Projects/Excursion_104/Excursion_104.htm
Seems like a good year to be in the tall pines down east.
 Post subject: Re: Update from upper Maine
PostPosted: Sat Jun 20, 2009 1:08 am
Latest news, don't expect steam in Phillips this year. Next year, likely. Meanwhile, rides will be offerred behind the Mustang powered 0-4-4T. I guess that still makes it an iron horse.
Additional repairs needed to the Monson #3 include resolving a crown sheet problem.
This project will cost money, and funds are being sought on the website.
http://srrl-rr.org/Projects/Monson_3/Monson_3.htm
PostPosted: Sat Jun 20, 2009 7:49 am
Those two footers have it made! Problem with the loco? Just load it up and haul it down to the shop whereas stadard gaugers have to bring the shop to the loco.
PostPosted: Mon Jun 22, 2009 11:52 am
Yes, you have that right!
I have seen the Monson locos at the Maine Narrow Gauge Museum, the WW&F Museum and static at Monson itself.
The size sure does help as well as having the Bickford Transportation Company with their Landoll trailer available.
It is sure great to have all five Two foot Locomotives back in Maine!
Some day it would be great to see all five of them running together again as they used to do at Edaville!
Ted Miles
PostPosted: Mon Jun 22, 2009 12:58 pm
Slight Clarification:
The "Fifth" remaining Maine 2ft locomotive, WW&F #9, never was part of the Edaville collection. WW&F #10, the current motive power for the WW&F Museum, was an Edaville locomotive, but saw very little service there. It was originally a Louisiana Sugar Plantation loco and was 30" gauge (re-gauged to 24" by Edaville.)
-Ed Lecuyer
PostPosted: Wed Mar 24, 2010 1:33 am
Are you ready for the grim news?
Monson 3 which was in for a tube job and some crown sheet repairs, began to tell a story of a boiler which was not fit for service without heavy repairs. Here is the word from Bob Troup at the SR&RL preservation group, describing the restoration which was supposed to be out of Boothbay last year and reassembled by now:
11/15/2009: The first thing is that Boothbay could not get it done before the end of November. As I wished to have #3 back by early December so we could have the winter to put it back together, I told them not to turn the drivers this year. [Webmaster's note: as part of the lease requirement "Turning the driver wheels, re-arching the springs, and repairing the water tank shall be completed by the Operator no later than December 31, 2013".] On Tuesday [Boothbay] called ... they had found more cracks and pockets in welds when they cut out the rest of the corners. In addition, more bad or broken stay bolts were found. These could not be seen until removal of the firebox corners. [Boothbay] placed calls to The State and Federal inspectors and [the MNGM and SRRL steam program leaders]. [MNGM and SRRL] agreed to the plan put forth by [Boothbay]. The Federal inspector did not wish to make a special trip so he said to do what ever was needed. [The State inspector] decided he needed to come and see the boiler himself. [Boothbay] started cutting into the firebox to find clean metal. Unfortunately they found more cracks and pockets in a longitudinal weld. They also found severe cracking in the stay bolts that they removed. [The State inspector] showed up while they were doing this. He was not happy with the situation. He ordered that all welds that the law covers be x-ray-ed. If they are found to be bad they are to be ground out and re-welded. Also if they could not prove that the stays had good welds all the stay bolts have to be replaced. This is between 200 and 300 stays. So far every weld that they have cut open has failed. It has been decided that the fastest and most economical way to accomplish this is to remove the boiler from the frame and place it on the shop floor. Also all flat sheets and the crown sheet will be cut out and replaced. The reason for this is that all of the stay bolt welds would have to be ground out and filled in. It is faster to install threaded stays and heat treatment is not necessary. The curved sheets will be ground and filled, as it will be faster and cheaper. The crown sheet is marginal so it is safer and smarter to replace it now. ... [Still hope to] have it running by July 4, 2010.
11/22/2009:On Friday [Boothbay] called and said that all of the welds had been x-rayed. All of the welds passed except on the backhead of the boiler. There are six roughly two-inch long bad spots. These can be ground out and re-welded and re-tested. The stay bolts are still all bad. We will still go ahead with cutting out the flat sheets and crown sheets and replacing them to speed things up and save money in the long run. ...
2/5/2010:...recently spoke with ... Boothbay about #3(MNGRR). [They] said progress was good. They have finished with all of the cutting out of bad metal and are preparing the boiler for welding in new metal. They are ordering the metal and building the forms they will need. Later this month they will begin heating and beating the new metal to shape it. ...
3/3/2010:...took a quick trip to Boothbay today. I took over 40 pictures. I deleted some of the worst ones. I apologize for the quality of some. I borrowed a digital camera and I'm not used to it. You will see the bad welds and the extent of the removal of material to fix all of the problems. You will see the new smokebox and the repairs being made to the curved sheets. The large shiny holes are where they have ground out the bad metal to find good. They will weld it back to size them for staybolts. You will see bad staybolts found throughout the boiler. Lastly you will see what a steam engine looks like inside. All of the various hidden parts are exposed for all to see. ...if anyone has access to an accurate lathe or can get a machine shop to donate some labor to turn Flexi-staybolts it will save us money. Flexi-stays cost $100 each. There are $2800 worth needed. Boothbay has the steel to make them and drawings to go by.
So, where does this leave us? Frankly, with no money at all! The lease agreement with Maine Narrow Gauge Museum calls for us to spend up to $25,000 for the boiler work and another $10,000 for the running gear work. Well, we have deferred the running gear work. The boiler work was originally expected to be a "simple" re-tubing with the asbestos abatement and inspections that come with that. But that scope of boiler work was only estimated at $18,000. As of March 1, 2010, the SR&RL has spent $28,000 and that doesn't include the $2,800 worth of flexi-stays. And the list of "to do" items goes on.
Image Image
Financial help is most needed for this project. Of course anyone who can venture to Phillips Maine would be greatly welcomed to for work on reassembling the locomotive, and for other pressing projects. Paypal and credit card donations accepted at the SR&RL website.
More about the Monson #3
PostPosted: Wed Mar 24, 2010 7:15 am
The Sandy River Line, is a new film created for the purposes of fundraising for No 3 -- all proceeds go directly to the continuing restoration of the locomotive. The program features 50 minutes of newly digitized original Newell Martin 16mm footage, taken between 1934 & 1936. Several minutes of Thomas T Taber footage is also included. Similar to our other efforts an elaborate synchronized soundtrack has been meticulously added. While I do apologize for the plug, my company makes no money from the sale of these dvd's, and it is for a good cause.
A clip can be found here: http://www.youtube.com/watch?v=bGEP289spD0
PostPosted: Wed Mar 24, 2010 11:58 am
http://srrl-rr.org/Projects/Monson_3/Monson_3.htm[/quote]
If you want all your money to go to your group, I sugguest people send a check. And not use credit cards or pay pal. If you do, a merchants charge or service charge has to be paid to the bank.Do you think they work free? We need every cent to go to these groups that we enjoy and love, and not be paying bankers to do it! The interest you save not charging you can send too!
