It is currently Sun Oct 18, 2026 10:43 am
 Post subject: Re: Simple Passenger Car Question
PostPosted: Wed Feb 20, 2002 12:35 pm
> On passenger cars, what is the vertical
> metal plate that surrounds the end door and
> acts as a buffer between connected cars. It
> has a bellows connected between it and the
> car body. What is that whole unit called?
You are probably asking about the diaphram face plate.
Don C.
old_fxrs@msn.com
PostPosted: Wed Feb 20, 2002 3:15 pm
The whole thing is called a diaphragm; the metal part is the face plate. The face plates from coupled cars slide against each other. Current cars have rubber diaphragms that resemble grain hoses.
They do not serve as buffers between the cars; passenger cars heve actual buffers at floor level.
The purpose of the diaphragm is to keep the weather off passengers walking between cars.
PostPosted: Thu Feb 21, 2002 5:59 pm
I suspect the tube diaphrams are more effective than the "accordian" type diaphrams. There also appears to be less hardware and much simpler construction. Am I right? Who manufactures these nowadays?
God Bless,
Gerald Kopiasz
> floor level.
hrrhs@aol.com
PostPosted: Thu Feb 21, 2002 6:47 pm
> God Bless,
> Gerald Kopiasz
We at San Diego Railroad Museum at about 15 years created a diaphragm by use 6" heavy rubber hose of a old fire truck ect with a standard plate to match the other cars.
It is still work.
owenpaulsen@att.net
PostPosted: Thu Feb 21, 2002 7:23 pm
You can getused grocery store checkout conveyor belts and tube them as well. This stuff also can replace rotted canvas in standard diaphragms.
Dave
irondave@bellsouth.net
