It is currently Wed Nov 04, 2026 11:52 pm
 Post subject: Strasburg 7312 Markings
PostPosted: Wed Aug 13, 2008 12:57 pm
Among other markings on the side of Strasburg 7312's cab is "30%." I think this was related to valve timing in a discussion here a while back, but I can't find the thread. If it's valve timing, what, exactly does that mean? If not, what is the meaning? Thanks
 Post subject: Re: Strasburg 7312 Markings
PostPosted: Wed Aug 13, 2008 1:07 pm
Canadian National used % as a shorthand to indicate a steam locomotive's tractive effort.
30% = 30,000 pounds tractive effort.
I hope this helps!
Steve Hunter
Cardinal, Ontario
PostPosted: Wed Aug 13, 2008 1:11 pm
30% x 1000lbs. tractive effort=30,000lbs.
S. Wayne Eissele
http://www.strasburgrailroad.com
wayne.eissele@strasburgrailroad.com
PostPosted: Wed Aug 13, 2008 4:27 pm
Last edited by Kelly Anderson on Sun Aug 04, 2024 6:51 pm, edited 1 time in total.
PostPosted: Wed Aug 13, 2008 4:33 pm
Kelly Anderson wrote:
#89 has 26% on the side of the cab. I think it means that in CN paint with the centered headlight, the engine looks 26% as good as it did in its old Strasburg scheme.
I'd say that's about right...
PostPosted: Wed Aug 13, 2008 4:58 pm
Amen
Gary
PostPosted: Wed Aug 13, 2008 5:28 pm
You guys STILL bitter about that?
PostPosted: Wed Aug 13, 2008 8:11 pm
Hi All
Cab marking,,,Strasburg # 7312,,,according too Canadian National Steam Power
by Anthony Clegg & Ray Corley,,,,
The answer is this,,,O -15-c build Kingston,Ont, 1912,,cyl 20+26 driver 51"
boiler pressure # 200 psi,,,,35% in CN terms is referred too Haulage rating,,this
term is referred as a designation of maximum ( starting ) steam locomotive
tractive effort...hopefully this is the answer you are looking for,,,Pat
PostPosted: Wed Aug 13, 2008 9:03 pm
It's been down-rated? 35% to 30%?
PostPosted: Thu Aug 14, 2008 7:36 am
