It is currently Thu Nov 05, 2026 5:03 am
 Post subject: Transition track and NG/SG turnouts where NG and SG seperate
PostPosted: Sun Dec 16, 2007 10:24 pm
Hi,
I do not recall which board had a discussion of how a switch that had the narrow gauge leave the standard gauge. I located a transition track used on a wye or a reverse loop and scanned it.
To make a switch out of it, the narrow gauge rails would cross the standard gauge rail with standard frogs.
I hope this helps some.
Doug Image
 Post subject: Re: Transition track and NG/SG turnouts where NG and SG sepe
PostPosted: Tue Dec 18, 2007 5:52 pm
Doug,
I believe the rail that takes the train from one side of the track to the other is called a "draw rail", and as you stated they have to get the train from the "wrong" side to the correct side of the track when a turnout is needed on the "wrong" side (whichever side that may be) on a given three-rail track.
David
