It is currently Sat Nov 21, 2026 12:09 am
 Post subject: 26L Training Class to be offered April 15,16,&17 2025
PostPosted: Fri Mar 28, 2025 2:28 pm
Why Teach the 26L Locomotive Air Brake System?
It is the dominant air brake system in North America. When you understand the 26L brake system,
you understand a great deal about today’s software driven electronic brake systems.
Your Three-Day Experience
If you have always wanted to be more effective at troubleshooting locomotive brake systems or you
just want to understand how the system works, this is the training for you. No hours of tracing
diagrams with colored pencils. Join your instructors for three 8-hour days of fast-paced learning as
we cover the four primary values and how they interact. Day one we explain the 26C automatic brake
valves and the signals it sends to other valves and participants learn a thorough locomotive brake
test. On the second day, we introduce the A-1 Charging Cut Off Pilot Valve found on many
locomotives and introduce troubleshooting equalizing reservoir leaks. That afternoon we present the
P-2A application valve and how it supports the use the dead man pedal, alertness devices, cab
signals and even PTC. On Wednesday we discuss the remedy to 10 common airbrake problems.
On day three we cover variations on the 26L system that participants may see on units from Class I
RRs, the compressed air system and more troubleshooting on a GP38-2 locomotive.
Your Instructors
Don and Allen worked at two different Class I “Granger Railroads” before meeting at Norfolk &
Western. Over the years they worked in as supervisors locomotive shops at Silvis, Decatur, and
Chicago, Illinois and managed larger shop teams at Roanoke, Va and Chattanooga, TN. Allen retired
as Manager of Locomotive Engineering and Don as Vice President Mechanical from Norfolk
Southern. Both have been involved in air brake modifications, test procedures, waiver applications,
specifications and troubleshooting since the ‘80s and have degrees in mechanical engineering.
The cost is $1000 per participant with a class size of 10 students. Payments are required in advance
by credit card to the Railroaders Memorial Museum. Payments can be made at this link:
https://www.railroadcity.org/trainings Participants should provide their address for informational
emails and pre-read materials.
Direct questions to Don Graab at ddgraab@gmail.com
