It is currently Sat Nov 21, 2026 12:20 am
 Post subject: Amtrak 4 bolt adapters
PostPosted: Tue Sep 17, 2024 12:25 am
Bearing box to P3 air decelostat adapter for roller bearing box - $500.00 each - Dallas Tx john@dalt.us
 Post subject: Re: Amtrak 4 bolt adapters
PostPosted: Wed Sep 18, 2024 3:19 pm
Pretty sure I found the same model for 375 bucks, up in Oklahoma. Don't recall the exact spot, some local shop…prices around Texas seem a bit high. Could save some dough if you're willing to dig around.
you might want to check out auto repair manchester nh and also check out
medical equipmentfor the best info
PostPosted: Fri Sep 20, 2024 11:20 am
That sounds quite reasonable. However, I recently came across a supplier in Houston who sells it for $400. So, you might want to check that out too.
