It is currently Sat Nov 21, 2026 1:46 am
 Post subject: Pyle National K240 Turbine
PostPosted: Fri Jun 18, 2021 2:20 pm
The turbine has had its bearings replaced and governor and throttle valve removed. The standard nozzle was replaced with a high pressure one to PN drawings supplied by Backshop Enterprises. The governor parts and old nozzle are included. The shaft has been shortened. It was supplying power to the accessory drive of a diesel generator engine equipped with a heat recovery steam generator in a test program I ran 10 years ago. The main case is broken at the exhaust pipe flange and the foot is broken off the inboard bearing housing. The turbine spools well with a 1/4" air supply. To run interdependently, you will have to rebuild and replace the original throttle and governor or come up with an external setup. Location: Sandpoint, ID Make offer. (208) 304-3454. mjanssen@vaporlocomotive.com
