It is currently Sat Nov 21, 2026 2:01 am
 Post subject: Shop equipment, physical plant stuff
PostPosted: Tue May 19, 2020 1:11 am
Grit blast cabinet - full size lighted, big double door unit w/large dust collector - Zero brand, best there is, 1500.00, super duty table base - suitable for truck tramming 1000.00, workbench, WW2 serious metal not today's flimsy stuff, from LTV plant 250/ couple different sizes w/backsplash. 60 HP freon compressor/motor 1500, 25hp air compressor w/tank - needs repair 500, Hibay lighting units 25.00 each, yes you can put LED bulbs in & just use the fixture, 48" exhaust fan & wall louvre 200. vertical stair unit 250, pedastal grinder 4x18" rocks (and stone are good condition) $1500, lost warehouse space so time to deal, HD parts room shelving 24x36 $5.00 each, you can't bend these. Tulsa winch, choice PTO or hydraulic drive $850. Surface grinder 18" mag chuck 750, drill/tool grinder 750. Bryant gas heaters, 500/pair. 4x8 wet vibratory table 1500. john@dalt.us for pix or questions - thanks Dallas Tx
