It is currently Sat Nov 21, 2026 2:26 am
 Post subject: Amtrak electrical / hardware etc
PostPosted: Sun Feb 16, 2020 2:01 am
Circuit breakers - new/used please quote your needs * Invertor 75vdc to 120 AC - new small unit $25 ea or 4 on panelboard w/terminal strip - 75.00 24-285-50124 * 2/0 crimp lugs 3/8 hole - box/50 -$20 * Threshold heater element $75 * Water heater element 480V top mount w/safety switch $100 * Agastat 6-60 minutes - delay relay so you don't overload the HEP/standby 25.00 24-015-01585 * Crouzet solid state timer QBS 30M T0802 $10. * Liquid level sensor w/float arm 24-729-01201 $25 * solenoid valve 1/8" 120V 24-729-00073 3cbx8bc $25 * 5KVA 480/240 or 240/120 single phase Jefferson all weather $150 4110111-000 * New Pyle-National cord ends, used swivel & fixed car body mounts * Used 27 pin Jbox $75 * HEP 6x6 Jbox new not 12x12 $350 * Bronze/SS vestibule hinges - pair 50.00 * Door latch/lock new SS 85.00 Budd 24-456-28625 * Emergency lighting kit including floor strips $500/car * Baseboard heater unit 34" 750 watts - 75.00 mounted in SS grille w/overtemp 24-120-21007 * Mulberry flooring 1 meter square panel $10 - 25 or more $7/each 24-090-90002 * Slide door operators electric 125.00 * railroad radio - cab mount 150.00 * please email for pix - more stuff at http://www.dalt.us * thanks john@dalt.us Dallas Tx
