It is currently Sat Nov 21, 2026 2:38 am
 Post subject: Wanted: Roller Bearing Wheelsets, 26L Air Brake Cores & More
PostPosted: Mon Nov 11, 2019 2:13 pm
All, I am looking for a minimum of four but preferably 8 roller bearing wheelsets for ALCO switchers fitted with GE 752 traction motors. I am looking for good RTO wheelsets with roller bearing journal boxes. Must be compatible for GE 752 motors, so the axle diameter must be 8 7/8 inches as I understand. Wheels should be not less than 2 inches remaning tread wear.
I am also after two sets of 26L rebuildable cores for conversion of 6SL/6L to 26FNL/26NL brake setups for those same switchers.
Also casually looking for one Nathan M3RT-1 air horn.
nathan-m3rt1-air-horn_1_4acaa62c5cb1f863645b00edf0eabbc2.jpg [ 26.23 KiB | Viewed 6772 times ]
Thanks!
Railroad Equipment Associates, LLC
Central Virginia & Western New York
