It is currently Wed Oct 07, 2026 8:29 am
 Post subject: Westinghouse AB gaskets
PostPosted: Thu Aug 16, 2018 9:59 am
Hi All
I am modeling a non-functional Westinghouse AB brake triple valve in 1-1/2" scale. I am modeling it in Solidworks and need a little help. I would like to purchase the gaskets that go on the pipe bracket. Part numbers 94783 and 94784. They can be used as long as they are in one piece.
Thanks
Tim Meyer
floridatenwheeler at Verizon dot net
 Post subject: Re: Westinghouse AB gaskets
PostPosted: Wed Aug 22, 2018 10:47 am
Hello. If I understand correctly, you just need one each of these two gaskets? If you haven’t already aquired them, send me a PM with your mailing address. I would be happy to give them to you.
Pete
