It is currently Wed Oct 07, 2026 4:00 pm
 Post subject: Wanted: Narrow Gauge Speeder trailer
PostPosted: Sun Sep 28, 2014 1:31 pm
Looking for one of these, but in Narrow Gauge.
http://www.carsoncolorado.com/images/MOWlaws.jpg
thanks,
David
 Post subject: Re: Wanted: Narrow Gauge Speeder trailer
PostPosted: Sun Sep 28, 2014 3:30 pm
Your best bet would be to shorten the axles on a standard gage trailer.
PostPosted: Tue Sep 30, 2014 2:07 am
You know the ends of those axles are tapered. Easier said than done.
Also, one axle is "split" with a simple differential arrangement to allow each wheel to turn independently. This is so crews can take the car off at a crossing by pivoting it 90 degrees. (hard to do with the rims fighting each other). The two half-shafts are of different lengths. If you build a car with 1 short and 1 long halfshaft, it comes out standard gage. If you use two short halfshafts, it comes out 36" gage.
PostPosted: Tue Sep 30, 2014 9:01 am
All it takes is a lathe...or a welder. It isn't difficult..... practically blacksmithing.
PostPosted: Tue Sep 30, 2014 10:58 am
Thanks guys, but I'd rather not do damage to a standard gauge trailer that might come in handy for someone else.
I'll figure something out...
David
PostPosted: Tue Sep 30, 2014 1:26 pm
There's always mine and industrial rail equipment dealers. You might need to make wider axles to expand these to 3 foot gauge. Many of the carts use wheel hub mounted roller bearings, so it's a much easier cut and paste alteration, and you can build a frame out of whatever you have handy.
