It is currently Wed Oct 07, 2026 3:02 pm
 Post subject: FP5 glad hand (pre 1962 style) needed DALLAS
PostPosted: Thu Apr 24, 2014 11:11 am
I have one modern air brake hose with a most modern FP5 glad with rear threaded coupling. Everything you would need to change it out on a freaight car. Its in great condition.
I need an old WABCO FP5 gladhand, The version of FP5 that I need was common untill about 1962, it has the over-rotation pin in it. I also need an old WABCO tapered plug angle cock too.
Rust covered is fine, the only important condition is that its wear surfaces are still intact and in newish tolerance. Even a broken hose is OK with me, I just need it to scan, not to use.
I'm in North Texas. Maybe one of the supporters of the FRISCO Rail Museum could use this to update one of the Passenger cars brake hose with.
PM me if you see this and well do some trading.
