It is currently Wed Oct 07, 2026 6:13 pm
 Post subject: Wanted Parts for F unit restoration
PostPosted: Mon Mar 24, 2014 10:42 am
I am looking for some parts removed from an F unit that we are attempting to get running again. We need a "button box" with 11 knobs that mounts to the side of the drum controller with the control, fuel pump, headlight, etc... switches in it and we need the engine control panel box that mounts to the left of the lay shaft. Its the box that contains the fuel pump switch, start and stop buttons, oil pressure and suction gauges, etc... Any leads on finding either of these would be greatly appreciated! Thanks
 Post subject: Re: Wanted Parts for F unit restoration
PostPosted: Wed Mar 09, 2016 7:40 pm
A you is the a F7A
And 4 to 6.pdf an second the Re;Wanted Parts F unit Restoration w/2
File comment: 3 of 6
F7A 3 of 6.pdf [283.48 KiB]
Downloaded 656 times
File comment: the 2
F7A 2 of 6.pdf [193.2 KiB]
Downloaded 529 times
File comment: ! of 6 a B&LE at to for a the new for can a print.
F7A 1 of 6.pdf [341.29 KiB]
Downloaded 577 times
PostPosted: Wed Mar 09, 2016 7:45 pm
4 to 6
File comment: 6 at 6
F7A 6 of 6.pdf [268.12 KiB]
Downloaded 554 times
File comment: 5 at 6
F7A 5 of 6.pdf [160.82 KiB]
Downloaded 585 times
File comment: 4 at 6
F7A 4 of 6.pdf [191.78 KiB]
Downloaded 651 times
