It is currently Wed Oct 07, 2026 2:40 pm
 Post subject: Wanted: Block heater for Alco S-3
PostPosted: Fri Jul 19, 2013 2:09 pm
We are seeking a 220V block heater for an Alco S-3. Please contact if you have one available.
Matt Bumgarner
Alexander Chapter-NRHS
SE Narrow Gauge & Shortline Museum
 Post subject: Re: Wanted: Block heater for Alco S-3
PostPosted: Fri Jul 19, 2013 9:31 pm
Matt, if your handy with plumbing and electrical, make your own, use a small circulating pump(household boiler type), and commercial grade water heater elements screwed into the ends of T fittings in a zig zag fashion, 3 4500 watt elements will keep your block warm. Install appropriate thermostat and contactors, all off the shelf items at a good plumbing supply house. Don't forget to install automatic drains in case of a power failure, I prefer the GURU brand.
Mike Tillger
