It is currently Wed Oct 07, 2026 4:41 am
 Post subject: National Pneumatic door opener controls
PostPosted: Thu Jan 31, 2013 1:03 pm
Anyone have a good lead for replacement/repair of the control coils for a National Pneumatic 64 volt door opener? Any leads on replacement coils, or somewhere to do a rewind would be most appreciated
magnetvalve.pdf [197.69 KiB]
Downloaded 547 times
Already have been down the multiple Wabtec roads (as successor to NP/Vapor), with no tangible success.
Please contact me at jisaksen@eldcps.org.
John Isaksen
 Post subject: Re: National Pneumatic door opener controls
PostPosted: Sat Feb 02, 2013 9:20 pm
John,
My suggestion would be to upgrade to a readily available Graham White Sales solenoid valve perhaps an 816 or 812 would work
http://www.grahamwhite.com/main/category.php?C1=1#Solenoid%20Valves
if not most motor shops will rewind magnet valve coils.
Mike Tillger
PostPosted: Mon Feb 04, 2013 3:21 pm
Thanks to RyPN's network of spies, we found out that the coils indeed are available from Vapor Bus/Wabtec.
http://www.vapordoors.com/
So, to steal a line from Arlo Guthrie, "if you may know somebody in a similar situation, or you may be in a similar situation..." the replacement Vapor Part # for the 64 volt coil in question is 56230472-04.
Thanks to Those in the Shadows who helped out!
John Isaksen
