It is currently Tue Oct 27, 2020 3:01 am
 Post subject: D13000 CAT Pony Motor 1949 American Locomotive crane 830D
PostPosted: Sat Jul 27, 2019 11:51 pm
Does anyone have adjustment info on starter clutch between the pony motor and D13000. The lever can go "over center" and it quits driving (cranking) - The Bendix engagement is fine - no issues there Thanks john@dalt.us
 Post subject: Re: D13000 CAT Pony Motor 1949 American Locomotive crane 830
PostPosted: Sun Jul 28, 2019 12:23 am
Should be a pin on the back of the pressure plate. Pull it out and rotate the plate clockwise looking toward the front of the engine. When adjusted properly the lever will snap in fairly hard. Make sure the pin drops back in when done adjusting. However going over center does not bode well, clutch disk could very well be shot. Never slip a Cat pony motor clutch snap it in quick. Everything on the pony was built to handle a lot more power than the engine can generate except the clutch.
PostPosted: Thu Aug 01, 2019 9:27 am
There is a guy on YouTube - Squatch253 . He restores and works on older cat equipment and has a bunch of videos on pony motors and drives. I don't think he has any videos on Cat D13000's but maybe the same principals are the same?
Users browsing this forum: No registered users and 72 guests
