It is currently Wed Apr 25, 2018 10:20 am
Post new topic Reply to topic  [ 72 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: GE 1941 23 Ton Switcher
PostPosted: Sat Aug 19, 2017 12:31 pm
I had a meeting with the Board of our RR society, and they were very positive about our efforts. One of the members is related to the owner of the local tourist RR, and offered some help in removing the housing over the diesel. That way we will have better access to the injectors.
Our basic starting point is to remove the injectors and run some oil into the cylinders. After that, we will try to bar the engine by hand to see if it can be turned over.We will also weld another support to take the strain off the cracked bell housing.
PostPosted: Sat Aug 19, 2017 10:27 pm
If you oil the cylinders leave the injectors OUT while it's being barred over, and leave them out until you can crank it over at regular speed and blow the cylinders out thoroughly. There is very little room in a diesel engine at TDC so it does not take much to hydrolock the engine, and when you do put the injectors in, it can easily start on that residual oil and potentially start to run away as it burns that oil off.
Robert Longhofer,
Board Member, Cotton Belt Rail Historical Society, Arkansas Railroad Museum, steam engine SSW819.
Any information or opinions I express are my own, and are not the views of the CBRHS or anyone else, unless explicitly stated otherwise.
PostPosted: Sun Aug 20, 2017 9:22 pm
Western Railway Museum didn't take this locomotive because it doesn't fit our collection policy (electric railways of the West or closely related). I'm glad it has found a good home.
Joe Magruder
PostPosted: Mon Nov 06, 2017 8:01 pm
We are finally starting to work on the engine. We just removed the stack and muffler so we can access the top of the engine. We plan to pull the injectors on Wednesday. We have been watching some Youtube videos on how to do it.
I also took about 30 photos of various parts of the engine and cab.
Once again,
We would like to thank all the members here that contributed their very valuable advice.
PostPosted: Wed Nov 08, 2017 8:41 pm
Today was the crucial day to work on the engine. I was afraid that every bolt and nut would be rusted and the engine would be a disaster.
Fortunately, that was not the case! All the bolts on the valve covers came off rather easily, and the valve train looked like it was brand new. No rust, no gunk, no foreign bodies.
We removed the #1 and #2 metering rods and springs and put each in a numbered ziplock bag.
We then drove into town and met with the Cummins people. They were very helpful and a mechanic showed us the special tool they use to remove the injectors. We then went to Harbor Freight and bought a similar tool.
After that we came home and soaked our tired bodies in the spa.
PostPosted: Wed Nov 08, 2017 9:57 pm
Soaked our tired bodies in the spa
OK, that is one accessory that would recruit a lot of members!
PostPosted: Mon Nov 13, 2017 7:17 pm
We made great progress today, we pulled all 6 injectors using a Harbor Freight $25 slide hammer instead of the Cummins $200 tool. We will take them in to Cummins to get them recalibrated.
Also, the good news was we were able to manually turn the engine (happy dance)
We do have a mystery, however. I ordered a rfeplacement Motorola Voltage Regulator, and found it is rated at 32 volts. The Alternator is a Motorola 24 Volt alternator. Also, the starter and solenoid are 24 volts.
From my understanding, the regulator would always have the alternator working. Can anyone help?
Thank you
PostPosted: Tue Nov 14, 2017 7:31 pm
Today was a banner day for us. We are going to send the injectors out to be cleaned and calibrated tomorrow. The local Cummins place said they send them out and double the cost. We are going to pack them up tomorrow and mail them to the place in Anaheim.
We also removed all 4 batteries from the cab to make room for the new ones. We got the information on the type of battery from the Cummins people.
We also removed the starter and starter solenoid so we can bench test them with the new battery. I am planning to buy the battery in the near future.
It is a heavy duty t24 volt truck battery.
I have also ordered the correct regulator for the alternator, plus a new alternator.
 Post subject: Re: GE 1941 23 Ton Switcher Help!
PostPosted: Thu Nov 16, 2017 1:38 pm
We have a puzzlement with this engine. The starter and solenoid for the Cummins is marked 24 volts.
The alternator is also marked 24 volts. BUT there is a 32 volt regulator hooked up to the alternator.
My worry is that the switcher control contactors operate on 32 volts, but the starter is a 24 volt starter.
Was this somehow jury rigged? I am not happy running a 24 volt starter at 32 volts.
PostPosted: Thu Nov 16, 2017 1:56 pm
I'm not sure how relevant this is, but I have a 1957 Allis D14 tractor that still has it's 6 volt starter motor even though the generator, regulator, battery and lights are 12 volt now.
Brian
PostPosted: Thu Nov 16, 2017 2:39 pm
If you don't like Jerry Rigged....you aint gonna be happy
your unit never had the starter from the factory.
The DC generator was originally used to crank the engine. Someone modified and added the starter.
How many cells does each battery have, and how are they connected?
Originally, you would have four batteries, with 4 cells each, 8 volts nominal, all connected in series, for a total of 32 volts. Each one of these is far bigger and heavier then any standard car, truck, tractor battery.
As for the starter and alternator, they will be fine on 32 volts. The starter in theory, should have a 32 volt solenoid installed, but it probably won't matter.
Robert Longhofer,
PostPosted: Thu Nov 16, 2017 10:42 pm
I worked on a airplane like that once.
The replacement engine, the Cummins NHC=250 has a starter
The original batteries were 4 cells each and connected in series for 32 violts
True
OK we will go with it
Thanks for all your inputs
 Post subject: Re: GE 1941 23 Ton Switcher help to Identify
PostPosted: Sun Nov 19, 2017 11:58 am
In the process of identifying everything changed on this switcher, I am not sure what this part is. The original 14E1 valve was replaced by an SA-2.
PostPosted: Sun Nov 19, 2017 12:39 pm
I am sure SA would be 'straight air' and that the trainline brakes have been eliminated
Robert Longhofer,
PostPosted: Mon Nov 20, 2017 11:29 pm
We are in the process of getting 3 Schedule 31 batteries that are rated at 1000 cranking amps, a number we got from the folks at Cummins.
Our first task is to check out the solenoid and starter to see if they need work.
If they check OK, we will remount them on the engine.
In the meantime we are fabricated an engine support to take the load off the bell housing.
We want to turn the engine with the injectors out to see what happens.
I am also checking prices on 32volt battery chargers. I got a call from the GNB Industrial rep who sent me some great data
Users browsing this forum: 70000, ColebrookdaleRailfan, frisco1630, Google [Bot], Harry Nicholls, Randy Hees, SR6900, traindude70, traingeek8223 and 43 guests
