Railway Preservation News http://rypn.org/forums/ |
Mount Rainier Scenic Railroad Returning to Operation http://rypn.org/forums/viewtopic.php?f=1&t=46901 |
Page 2 of 2 |
Author: | Bobharbison [ Wed Mar 15, 2023 1:36 pm ] |
Post subject: | Re: Mount Rainier Scenic Railroad Returning to Operation |
KevinM wrote: Tom, Any idea why the 91 is lettered for West Fork? It is unusual for a place that billed itself as a museum to letter a locomotive for a legacy railroad that never owned it. /Kevin Madore The real Heisler 91 operated in Mineral and the surrounding area for the West Fork Timber Co. West Fork Timber was the Murray Pacific Logging Operation. Tom Murray founded the museum and provide significant funding. Had the real #91 still existed, he would no doubt have restored it. But it was scrapped. The 102 was a close match, though not identical. It's certainly a reasonable stand-in for the locomotive that operated in the area. Sometimes when the actual artifact is no longer available, you have to work with what you have. Some tourist railroads use stand-ins, others avoid the issue by using their own road name instead. As long as it's documented, I don't see it being a problem. |
Author: | Bobharbison [ Fri Mar 17, 2023 12:37 am ] |
p51 wrote: I find it interesting that the current plan is to build infrastructure in Eatonville and apparently move all the shops and the logging museum (which was moved down from Tacoma several years ago) to there. That is incorrect. A station and engine house will likely be constructed in Eatonville. The shops and museum will remain at the current location. That provides the passengers with a destination rather than just a train ride. |
Author: | p51 [ Fri Mar 17, 2023 1:55 am ] |
Bobharbison wrote: p51 wrote: I find it interesting that the current plan is to build infrastructure in Eatonville and apparently move all the shops and the logging museum (which was moved down from Tacoma several years ago) to there. That is incorrect. A station and engine house will likely be constructed in Eatonville. The shops and museum will remain at the current location. That provides the passengers with a destination rather than just a train ride. |
Author: | Kimball B. McGinley [ Mon Mar 20, 2023 12:06 am ] |
I suspect the change from 24:12 to 24:11 was not done for increased tractive effort, but for increased gear life. In a 24:12 pair, any defect that begins to appear on a given tooth will soon transfer that defect to the mating 2 teeth. The 24:11 pair is known as a "hunting teeth" pair since the gear mates are constantly shifting. This is a common technique for extending gear life. |
Author: | linkthebutler [ Mon Mar 20, 2023 2:39 am ] |
Sorry Kimball, that is wrong. From todays engineering view...yes maybe. But we are in the summer of 1928 and Heisler Locomotive Works with just a single product fight for survival against the major competitors. The goal ws to distant themselves from the 38.000 lbs TE Lima 3-PC-13, Baldwin 16_28/46_1/4-DD and reach the 43.000 lbs TE of the Baldwin 16_30/50_1/4-DD. PS the 24:12 worked well in all Pickering Heisler until today. |
Page 2 of 2 | All times are UTC - 5 hours [ DST ] |
